Rough estimate: I believe the 5vz starter motor is a 2000 watt job. So 2000/12volts = about 167 amps needed (minimum).
Here in central tx, i just buy the cheapest wallymart batt this is the largest that fits, they all cost $49. No batts last more than 3-4 yrs in the severe texas heat so I don't bother with expensive batts.
